Hello All! I am looking for a new router that will cover the following needs:
Internet - 1gb/s incoming by LAN cable but optionaly will be upgraded to optical cable. (bear with me)..
Must have: or strongly desirable -
1. Wireless - would like to have Wi-Fi 6E.
2. At least 6 LAN ports.
3. Extreme security - highest possible level, will be strong preference. Fully supported device with regular firmware/software update.
4. Should be able to pass through TV signal...
5. Will be veryy nice to have optical port and "regular" lan port, and modem style coaxial connection for the incoming internet.. (so all of the 3 if that is possible at all...)
Will be attached to - 3 wireless devices, 2 PC, 15~ Iot's , and Pi4B. 2 VPN connections will be needed too...
Can you please give an advice what is the closest possible solution? Budget is high, as soon as i can get all what i need...Thanks in advance to all!
BR!
BR!
