new solid state drives for NAS / router testing
Windows has a lot of overhead in NTFS and NTFS<->samba. I think it's more than a NAS and its file system as Linux drivers and stacks tend to be leaner and less layers of abstraction than in .net.
A good bit of the NTFS functionality is moved to Samba (such as ACL handling), so that pretty much offsets any "benefit" you might have from using a leaner filesystem such as ext4. And that's assuming you don't use a filesystem with native ACL support, such as xfs.
ext4 generally will give better performance than NTFS on a Linux platform - the ntfs driver is getting better all the time, but ext4 is far more mature...
My experience is that NTFS on LInux and the NAS is much slower than under windows, and for writing, much, much slower. Like 50%.
re post #22 - confuses me - my point was that NTFS on windows combined with samba is much slower than windows-to-windows LAN transfers.
Windows to Windows is still "Windows with NTFS", so I don't understand your performance claim here. If Samba runs on the remote Linux endpoint, then it doesn't matter which filesystem the Windows client runs - the potential bottleneck will be the filesystem used on the Samba server.
My experience is that NTFS on Linux and the NAS is much slower than under windows. I used to do external backups to extfs for speed reasons. I can read extfs when the drive is plugged into a windows PC. But now I use NTFS on the external backup drive. After the first backup, the deltas do take a lot longer, but a half hour or so. And I just let it run. There are manually initiated backups because that external 2TB 2.5 in. drive is hidden away when not in use.
That's about all there is to say.
And that is definitely correct, especially when using NTFS-3G. We were just talking about two different things there.
Oh. NTFS-3G .. new term for me.
There's a couple of NTFS drivers - ntfs3g is one, and there's the FUSE NTFS driver - both are more focused perhaps on doing it right, so performance compared to native file systems takes a back seat...
NTFS-3G is the most commonly used NTFS driver for Linux. Its main developer, Tuxera, also sell a high performance commercial product, which is used by Asus in their newer ARM-based routers. I think QNAP also uses the Tuxera commercial driver.
(as an aside, I exchanged a few emails with the Tuxera CEO a few years ago. Really friendly guy.)
The other well-known product is from Paragon, who has a free-for-personal-use driver, as well as a high performance commercial solution. The Paragon solution is used by Asus's MIPS routers, as well as a number of other router and NAS manufacturers (such as Asustor). WD also uses it for the WDTV.
The performance of these commercial solutions is fairly decent. I can push my RT-AC88U to over 80 MB/s with it, over USB 3.0 (despite BCM's poor USB 3.0 design). What is usually more worrying is the reliability. Paragon used to be pretty bad at corrupting filesystems back to its 8.5/8.6 releases, for instance.
The performance of the open sourced products however is pretty average.
I too had problems with data corruption using the Paragon driver. I haven't tried it lately though.
