Hi all,
I'm researching my first NAS for my home LAN. My current plan is to get a single-bay NAS, and back it up to an external USB drive -- and ideally I will cycle the external USB drive to keep a copy off-site.
Right now my network is mostly Mac clients, though up until a year or so ago it was PCs. I don't use Time Machine -- instead, I use ChronoSync (when I used PCs, I used something similar called Second Copy) to copy folders to a remote drive. So, my intention is to use ChronoSync to send folders to the NAS, and to back the NAS up to the USB.
Anyhow, my question relates to the external USB drive that would be attached to the NAS -- I gather I can't simply move that drive to my Mac and be able to use it? (meaning, in case of some emergency.)
In my ideal world, it seems best if I can detach the USB from the NAS, and plug it into a Mac or a PC, and use it.
But it seems there isn't an easy way to do that? From what I understand (I'm no expert), exFAT would be ideal as it works on Mac and PC -- but exFAT isn't an option for the NAS.
What is the "smart" way to format that external USB drive? Am I "wrong" to be thinking I need to be able to have easy direct access via Mac or PC? I think I'm leaning toward NTFS, because (I believe) it's at least readable on Mac, and works on PC, but I'm not really sure, and hopefully someone might share some guidance.
On a related note, when I save some Web page link files, sometimes they have a "|" in the file name -- and when I back that up to my remote now (an NTFS drive attached to an old PC via USB), those files fail -- I'm hoping to eliminate those sorts of pesky issues.
Thanks kindly for any thoughts! -Scott
