New to VPNs so I have a question
Lee MacMillan
Dangling my toe into the VPN waters with the free version of Proton. I have it installed only on my hardwired desktop (Windows 10) PC. I am using an Asus AX86U with the latest Merlin firmware. No noticeable speed drop and it's pretty transparent so far. Just a couple quirks or possibly just my lack of understanding of how it works. Anyway, it won't let me log into my router which is not a big deal since connecting and disconnecting from the VPN is easy. Only one site so far wouldn't let me in and that was fitbit.com which I found a little odd. It gave me a message indicating it didn't like the IP address. Yet, the next time I tried, it was ok. So I guess that was just a fluke.
So the question is why is the VPN preventing me from logging into my router? Is it a Merlin issue, a general VPN issue or a Proton-specific VPN issue. The message I get from Chrome is:
This site can’t be reached​
router.asus.com’s server IP address could not be found.
Crimliar
When you use a VPN, you are creating a Virtual Tunnel for your traffic from the client device running the VPN software to the server you are connecting to. Running the VPN client on your computer, then everything on your local network is outside of that tunnel and so you won't be able to connect to it. So that's not just your router but any local printers, or other devices etc.
There are ways around that limitation if you need them - the simplest being to run the VPN client on the router rather than on your local machine!
philote
Most VPN providers, including Proton, let you access the local network as they don't tunnel local connections through the VPN.
router.asus.com works when you're not connected to a VPN because the default config for a router's DHCP DNS setup is the router itself, if you have DHCP enabled (which is also default). So when a client queries the IP address for the domain, the router returns it's own local address before routing the DNS query externally.
You should still be able to connect to the router by specifying the IP address of the router itself instead of using router.asus.com. If you go to your computer's network settings & check your LAN details, it should look something like this:
IP address: 192.168.50.101
Subnet mask: 255.255.255.0
Router: 192.168.50.1
DNS servers: 192.168.50.1
Lee MacMillan
That worked, thanks.
