Newbie Question bypass VPN
filterxg
I'm using a VPN on my ddwrt router, but I'm tired of the blocks on Netflix, so I'd like to have the local IPaddress of the streamer bypass the VPN. I don't think I want to set up a dmz as I want to keep my firewall rules, and I don't want to set up a second network as I want to keep access to my NAS.
I know Google is my friend on this but I seem to be using the wrong keywords. Every search gives me mostly results on bypassing VPN blocks... Not admitting defeat and bypassing the VPN entirely.
What settings do I need to research?
Thank you
Sent from my SM-G950F using Tapatalk
Sounds like a question for the DD-WRT forums. Look for information regarding "policy routing" or "split tunnelling".
Thank you I'm finding what I need now
This are two methods is use on Asuswrt routers you can look at here: https://github.com/Xentrk/netflix-vpn-bypass
I know DD-WRT did not come with ipset installed last time I used it. I had to side load it by asking for the binary on the forum. The ASN method may work with some minor mods on the DD-WRT.
L VPN service question VPN 9
