Newbie to Merlin/Scripting - SSH script query
AsusNovice
Thank you for any help that can be provided, I have made reasonable efforts to search for answers ;)
Asus RT-AC86U with Merlin 386.3_2. I have used Asus routers for VPN as server and client for some time, but only recently into merlin and now scripting. Experienced C/Windows programmer, which is no doubt a hinderance getting to grips with Linux and SH scripting :mad:
This link is similar to what I am attempting - automatically create a reverse SSH tunnel from the Asus to a known point in the outside world. I have got to:
  • Using Putty to login into router
  • Got scripts running both manually executed, and automatically [e.g. wan-event], and decoded / acting on the $1/$2 entry parameters.
  • Logging to an output file the progress of the script.
  • Getting the rev SSH tunnel setup from the command line:
    dbclient -p xxxx -i /jffs/.ssh/asus -y -R 0.0.0.0:yyyy:localhost:zzzz user@domain.net
What I have yet to crack is getting that line to 'execute' from within the wan-event script; and when I do I'd like to be able to log any output, and keep it running after the script completes. From the thread above, and research, the clue might be in a trailing '&' and/or a leading 'nohup'? I have tried random variations, and strategically placed sleep 10s commands, but no luck. My "log" file (using >> commands) seems to ignore that line.
Any (gentle :rolleyes:) advice / suggestions welcome ...
AN
Some forum gurus may correct me on this but in wan-event it should be as easy as
[ "$2" = 'connected' ] && sh /jffs/scripts/mycustomscript.sh > mycustomscript.log 2>&1 &
Thank you again :)
That is exactly the issue I had partially solved, but wanted to complete and automate... Not over 4G but from behind Starlink which is also CGNat - and then VPN over the tunnel into the Asus VPN server.
Easy question - I assume on the Asus Merlin dbclient is identical to ssh? i.e. the installed ssh is dropbear's client
AN
