NextDNS
keef
Hello. Installing NextDNS I entered a saved ID and the setup seemed to go ok. From the my.nextdns.io page it says "This device is not using NextDNS.". I entered the DNS servers manually and I still get the same message. It says I'm using ”AMANAHA-NEW” as DNS resolver. I have no idea what that is!
I am using Merlin.
thanks
I am using Merlin.
thanks
They look to be a cloud infrastructure provider in Canada. If that’s where you are, maybe they’re hosting the Nextdns stuff near you?
Set it up with DoT.
I know that well , good luck
It can be dicey. A quick trip out for them gave me some time. I made the changes and no luck, I get the same info screen. I also shut down my VPN (Nord) and used a different browser to get around any cached info.
The field 'Enable DNS-based Filtering' should that still be ON and pointing to Router?
thanks
The way I have mine set up is....
Lan , DHCP server , DNS server 1&2 both blank
DNS Director on , Global redirection set to router to force all traffic through WAN DoT
WAN DNS server blank , with DoT enabled
EDIT;; are you using the NextDNS CLI?
SevenFactors NextDNS CLI Merlin GUI Asuswrt-Merlin AddOns 14
L NextDNS Windows installler Asuswrt-Merlin AddOns 15
