A) Is there a way to automatically create the NFS mount-points eg. /mnt/nfs /mnt/nfs2 during router boot ?
I have the mount in my /jfs/scripts/fstab.postconf:
mount -t nfs 192.168.1.102:/volume1/public /mnt/nfs -o nfsvers=3,nolock,_netdev,rsize=8192,wsize=8192
It works manually after I create the folder with mkdir /mnt/nfs
B) In the merlin source it says the NFS 4 is supported.
https://github.com/RMerl/asuswrt-merlin/blob/master/release/src/router/nfs-utils/utils/mount/nfs.man
Is that correct ? How to I set my mount to NFS4?
cheers
chris
Synology settings:
shared folder - permissions - system internal users: anonymous check read
NFS:
hostname: *
Privilege: read
Squash: map all to admin
security: sys
cheers
chris
Synology settings:
NFS:
hostname: *
Privilege: read
security: sys
