Alex Tzonkov
Hi, I have been trying to enable my R7800 with Voxel FW (V1.0.2.75.2SF) on it to export my external USB drive via NFS, and so far I am not having much luck. Has anyone in this community done it successfully and is willing to share?
Here is what I have been able to do so far:
When I try to look at the nfs-kernel-server package it is looking for portmap (which I think is a precursor to rpcbind), maybe there is a newer version of it which works with rpcbind?
unfs3 seems dead as well:
At this point, any pointers or help would be appreciated.
- Install Voxel Firmware + Kamoj Addon V5
- Enabled SSH access and installed Entware as per Voxel's readme
- I think I opened the NFS ports (111, 2049) using the directions from the Readme.
- Installed nfs-kernel-server and rpcbind, I even tried installing unfs3 package.
root@R7800:/tmp/mnt/sda1/entware/etc/init.d$ ./S19rpcbind check
Checking rpcbind... alive.
root@R7800:/tmp/mnt/sda1/entware/etc/init.d$ ./S19rpcbind restart
Shutting down rpcbind... done.
Starting rpcbind... done.
root@R7800:/tmp/mnt/sda1/entware/bin$ ./rpcinfo
program version netid address service owner
100000 4 local /opt/var/run/rpcbind.sock - superuser
100000 3 local /opt/var/run/rpcbind.sock - superuser
100005 1 udp 0.0.0.0.151.204 - superuser
100005 1 udp6 ::.189.153 - superuser
100005 2 udp 0.0.0.0.171.102 - superuser
100005 2 udp6 ::.214.186 - superuser
100005 3 udp 0.0.0.0.179.185 - superuser
100005 3 udp6 ::.164.169 - superuser
./S57nfs-kernel-server check
Error: portmap not started
root@R7800:/tmp/mnt/sda1/entware/etc/init.d$ ./S56unfsd check
Checking unfsd... dead.
root@R7800:/tmp/mnt/sda1/entware/etc/init.d$ ./S56unfsd start
Starting unfsd... failed.
