Hey guys, which router between the two should I get and why? They are the same price on Amazon right now.
Thank you for your help.
but i don't know if i'll ever get a use of it.
Both the netgear and tp-link are really high rated.
Obviously Asus, anything more?
ok, i will check out ASUS AC3200 (which is the same as AC88U but with 4 ports instead of 8?).
doesn't software reflect on wireless performance?
Synology AC2600
Asus AC3200.
The AC88U is 100 USD more than R7800 where i live.
tbh its worth the $100 more
the r7800 is only 1733M on 5 gig , the 88u is 2156M plus 8 ethernet ports and link aggregation and the asus gui
The following reviews show the R7800 which is "only 1733M" actually has better range and speed on 5Ghz at both close and far ranges
but not so much because of "2165 vs 1733" advertising. Most laptops with Intel or Atheros adapters and most phones don't even support NitroQAM which is a Broadcom proprietary feature, kinda gimmicky and just to inflate numbers on packaging.
Nothing wrong looking at the Synology AC2600 either,
Welcome To SNBForums
