Skynet No data to display in Skynet Statistics
qy2009
Everytime I open Skynet Statictics , the log size is zero. and "no data to display". however it has banned so many IPs ?
I tried uninstalling Skynet and re-install for 3 times. still the same result.
thanks
Have you clicked update stats yet?
Sometimes it takes 12 hours or so to kick in from memory, have another look tomorrow. It may well have kicked in.
mmm very strange, have you tried reformating your usb stick/drive (swap file)
Click update and then check the system log for clues.
Do you even have Skynet logging enabled? Are you in a double NAT setup that prevents outside traffic from reaching the Asus firewall?
Something is messing with your skynet log file, it’s 0 bytes in size despite hits on your iptables counter.
Check your other addons for interference.
@Adamm I only have these installed:
1 open Diversion v4.2.2
2 open Skynet v7.2.8
j5 open uiDivStats v3.0.2
I did [12] Debug options, here is the result:
| Test Description |                | | Result |
Internet-Connectivity               | [Passed]
Write Permission                    | [Passed]
Config File                         | [Passed]
Firewall-Start Entry                | [Passed]
Services-Stop Entry                 | [Passed]
Service-Event Entry                 | [Passed]
Profile.add Entry                   | [Passed]
SWAP File                           | [Passed]
Cron Jobs                           | [Passed]
NTP Sync                            | [Passed]
IPSet Comment Support               | [Passed]
Log Level 5 Settings                | [Passed]
Duplicate Rules In RAW              | [Passed]
IPSets                              | [Passed]
IPTables Rules                      | [Passed]
Local WebUI Files                   | [Passed]
Mounted WebUI Files                 | [Passed]
MenuTree.js Entry                   | [Passed]
| Setting |                         | | Status |
Skynet Auto-Updates                 | [Enabled]
Malware List Auto-Updates           | [Enabled]
Logging                             | [Enabled]
Filter Traffic                      | [Enabled]
Unban PrivateIP                     | [Enabled]
Log Invalid Packets                 | [Disabled]
Import AiProtect Data               | [Enabled]
Secure Mode                         | [Enabled]
Fast Switch List                    | [Disabled]
Syslog Location                     | [Default]
IOT Blocking                        | [Disabled]
Country Lookup For Stats            | [Enabled]
CDN Whitelisting                    | [Enabled]
Display WebUI                       | [Enabled]
18/18 Tests Sucessful
I got a few data also:
[1-15]: 13
Select Stat Option:
[1]  --> Display
[2]  --> Search
[3]  --> Remove
[4]  --> Reset
[1-4]: 1
Show Top x Results:
[1]  --> 10
[2]  --> 20
[3]  --> 50
[4]  --> Custom
[1-4]: 1
Show Packet Type:
[1]  --> All
[2]  --> TCP
[3]  --> UDP
[4]  --> ICMP
[1-4]: 1
[$] /jffs/scripts/firewall stats 10
[*] No Logging Data Detected - Give This Time To Generate
What are the settings on the System Log page for log levels?
How about the output of this ssh command?
ls -l /tmp/mnt/*/skynet
/tmp/syslog.log:May  4 05:01:50 Skynet: [*] USB Not Found - Sleeping For 10 Seconds ( Attempt 1 Of 10 )
  408 me        1444 S    /sbin/syslogd -m 0 -S -O /jffs/syslog.log -s 256 -l 7
  411 me        1444 S    /sbin/klogd -c 5
12144 me        4728 R    grep logd
But I have my USB(I am using a SD card as my flash drive broke so many times with different ones) plugin.
The issue is that your syslogd is writing to /jffs/syslog.log instead of /tmp/syslog.log. Skynet cannot find the entries. How did you make it do that?
Edit: you must have one of the new routers that have the PSISTLOG build option. Not sure if @RMerlin wants to keep it that way, or if @Adamm needs to contemplate that difference.
