Any idea why the sitemap does not load? I see the user1.asp as expected, but user2.asp just shows:
"This page shows a dynamically generated sitemap of the router WebUI. Provided by scMerlin.
Show page URLs? [ ]" with a checkbox that will not stay checked.
Note the device is running in "Repeater Mode" which I know disables some menus, so perhaps related to that.
The following is all I see in the logs:
Apr 2 08:57:01 rc_service: httpd 1194:notify_rc start_scmerlingetaddonpages;start_scmerlingetcronjobs
Apr 2 08:57:01 custom_script: Running /jffs/scripts/service-event (args: start scmerlingetaddonpages)
Apr 2 08:57:02 custom_script: Running /jffs/scripts/service-event (args: start scmerlingetcronjobs)
Apr 2 08:58:31 acsd: selected channel spec: 0x100a (10)
Apr 2 08:58:31 acsd: Adjusted channel spec: 0x100a (10)
Apr 2 08:58:31 acsd: acs_set_chspec: 0x100a (10) for reason APCS_CSTIMER
Apr 2 09:00:24 rc_service: httpd 1194:notify_rc start_scmerlingetaddonpages;start_scmerlingetcronjobs
Apr 2 09:00:24 custom_script: Running /jffs/scripts/service-event (args: start scmerlingetaddonpages)
Apr 2 09:00:24 custom_script: Running /jffs/scripts/service-event (args: start scmerlingetcronjobs)
Apr 2 09:01:13 rc_service: httpd 1194:notify_rc start_scmerlingetaddonpages;start_scmerlingetcronjobs
Apr 2 09:01:13 custom_script: Running /jffs/scripts/service-event (args: start scmerlingetaddonpages)
Apr 2 09:01:14 custom_script: Running /jffs/scripts/service-event (args: start scmerlingetcronjobs)
Apr 2 09:02:02 rc_service: httpd 1194:notify_rc start_scmerlingetaddonpages;start_scmerlingetcronjobs
Apr 2 09:02:02 custom_script: Running /jffs/scripts/service-event (args: start scmerlingetaddonpages)
Apr 2 09:02:02 custom_script: Running /jffs/scripts/service-event (args: start scmerlingetcronjobs)
