Node with wireless backhaul - Connection between 2 LAN devices on the node
Aarto Reponen
Hi
I have two GT-AX11000 routers. One in my living room (connected to Internet modem) and another one in my office set up as a AIMesh router with wireless backhaul.
In my office, i have connected a PC and NAS on the LAN ports. Should/can the traffic between these two be routed directly on the node router without having to go through the backhaul?
Right now, i am only getting 73MB/s file transfer rate so it appears the traffic is being routed through the main router instead of directly between the devices attached to the LAN ports on the mesh node?
(and yes, QoS is turned off)
With kind regards
Aarto
