connorm
i have been looking at the wireless logs lately to see how everything is connected as 3 people in the house just moved downstairs alot farther away from the router, why does each wireless adapter show noise of -91 or -89 and why are the 5ghz devices all negative rssi and all the 2.4 are positive, yet the 5ghz have good connection and the 2.4 sucks
SSID: "McCaffrey2.4GHz"
RSSI: 0 dBm SNR: 0 dB noise: -90 dBm Channel: 1l
BSSID: 740:2B:86:75:78 Capability: ESS ShortPre ShortSlot
Supported Rates: [ 1(b) 2(b) 5.5(b) 6 9 11(b) 12 18 24 36 48 54 ]
HT Capable:
Chanspec: 2.4GHz channel 3 40MHz (0x1803)
Primary channel: 1
HT Capabilities:
Supported MCS : [ 0 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 32 ]
Mode : AP Only
Stations List Rx/Tx Speed RSSI State
5C:59:48:63:10:XX 192.168.1.110 Chrisitian 65/39 Mbps 14 dBm assoc auth
CC:08:E0:70:0B:XX 192.168.1.105 Connors-iPhone ??/52 Mbps 13 dBm assoc auth
E0:CA:94:6F:9D:XX 192.168.1.103 Chris-PC 54/27 Mbps 33 dBm assoc auth
SSID: "McCaffrey5GHz"
RSSI: 0 dBm SNR: 0 dB noise: -89 dBm Channel: 36/80
BSSID: 740:2B:86:75:7C Capability: ESS
Supported Rates: [ 6(b) 9 12(b) 18 24(b) 36 48 54 ]
VHT Capable:
Chanspec: 5GHz channel 42 80MHz (0xe02a)
Primary channel: 36
HT Capabilities:
Supported MCS : [ 0 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 ]
VHT Capabilities:
Supported VHT (tx) Rates:
NSS: 1 MCS: 0-9
NSS: 2 MCS: 0-9
NSS: 3 MCS: 0-9
Supported VHT (rx) Rates:
NSS: 1 MCS: 0-9
NSS: 2 MCS: 0-9
NSS: 3 MCS: 0-9
Mode : AP Only
90:27:E4:F8:FC:XX 192.168.1.108 Ren 108/13 Mbps -77 dBm assoc auth
00:25:AE:65:00:XX 192.168.1.102 * 150/27 Mbps -71 dBm assoc auth
58:55:CA:1E:B4:XX 192.168.1.104 Apple-TV 58/19 Mbps -77 dBm assoc auth
HT Capable:
Primary channel: 1
HT Capabilities:
Mode : AP Only
VHT Capable:
Primary channel: 36
HT Capabilities:
VHT Capabilities:
NSS: 1 MCS: 0-9
NSS: 2 MCS: 0-9
NSS: 3 MCS: 0-9
NSS: 1 MCS: 0-9
NSS: 2 MCS: 0-9
NSS: 3 MCS: 0-9
Mode : AP Only
