ijjdevilliers
Downloaded the firmware and upgrading with Merlin but the firmware stays on the stock firmware after installation and it doesn't change to Merlin. Any ideas?
It's an Asus rt-ax56u and trying to upgrade to firmware version386.2_2 downloaded from sourceforgeDownloaded the firmware and upgrading with Merlin but the firmware stays on the stock firmware after installation and it doesn't change to Merlin. Any ideas?
I get no errors. Everything runs normally. But after a reboot no changes occurredIt's an Asus rt-ax56u and trying to upgrade to firmware version386.2_2 downloaded from sourceforge
www.snbforums.com
www.snbforums.com
Will do thanks![]()
Release - Asuswrt-Merlin 386.2 is now available
Update (30-Apr-2021): 386.2_4 is now available, updating OpenVPN and with a few minor changes. Update (13-Apr-2021): 386.2_2 is now available, addressing a few minor issues. Asuswrt-Merlin 386.2 is now available for all supported models. This release introduces support for the GT-AX11000 and...www.snbforums.com
Just flashed 386.2.2 Working good, as stated ICMPv6 is now back to the way it should be. Thank You @RMerlin. Just seen this anything to be concerned about ? DNS Vulnerabilities Expose Millions of ... (darkreading.com) From that article: The four stacks in which the vulnerabilities...www.snbforums.com
You're not alone.
I had to use Recovery mode and a CLI TFTP program to update the firmware.
You might try the same.
Welcome To SNBForums
