NT-N660 - OpenVPN with IOS Connect Issue
GMan23
So I gave up on PPTP since my IOS Devices I want to use for VPN support OpenVPN.
I am having issues connecting with OpenVPN on my IOS Devices even when connected to the Lan.
I reset my Router back to Factory (Merlin Latest) Build and re-configured my LAN.
Did a setup with Default settings except Require U/P for OpenVPN Server on the router.
Got the OpenVPN connect config file and put it on my IOS Device.
When I try to connect I get the following in the ASUS Syslog below
Jan 12 16:24:41 openvpn[936]: 192.168.1.2:59733 TLS: Initial packet from [AF_INET]192.168.1.2:59733, sid=af5df47c 450bb67d
Jan 12 16:24:51 openvpn[936]: 192.168.1.2:54652 TLS: Initial packet from [AF_INET]192.168.1.2:54652, sid=360ce8a3 95bbc7d6
Jan 12 16:25:01 openvpn[936]: 192.168.1.2:58514 TLS: Initial packet from [AF_INET]192.168.1.2:58514, sid=93cf776c 253d83fd
Jan 12 16:25:11 openvpn[936]: 192.168.1.2:63747 TLS: Initial packet from [AF_INET]192.168.1.2:63747, sid=382d27f1 5e75dae9
Jan 12 16:25:21 openvpn[936]: 192.168.1.2:57737 TLS: Initial packet from [AF_INET]192.168.1.2:57737, sid=ac37d0b7 be75e962
Jan 12 16:25:41 openvpn[936]: 192.168.1.2:59733 TLS Error: TLS key negotiation failed to occur within 60 seconds (check your network connectivity)
Jan 12 16:25:41 openvpn[936]: 192.168.1.2:59733 TLS Error: TLS handshake failed
Jan 12 16:25:41 openvpn[936]: 192.168.1.2:59733 SIGUSR1[soft,tls-error] received, client-instance restarting
Jan 12 16:25:51 openvpn[936]: 192.168.1.2:54652 TLS Error: TLS key negotiation failed to occur within 60 seconds (check your network connectivity)
Jan 12 16:25:51 openvpn[936]: 192.168.1.2:54652 TLS Error: TLS handshake failed
Jan 12 16:25:51 openvpn[936]: 192.168.1.2:54652 SIGUSR1[soft,tls-error] received, client-instance restarting
I did have to add setenv CLIENT_CERT 0 to the end of the config file otherwise it required a Key to try and connect on the IOS Device. I got that setting from another post.
Anyone with this router with using OpenVPN with IOS Devices have any ideas on what I am missing??
Thanks..
hi, can you take a screenshot of your openvpn server settings? (not the keys lol)
