ntpMerlin ntpMerlin errors on 386.7_2
Protik
Recently upgraded my AC68U to 386.7_2 and ntpMerlin is behaving a bit weird. The UI is showing up like this:
Bash:
6.    Set number of days data to keep in database
      Currently: trueDAYSTOKEEP days data will be kept
s.    Toggle storage location for stats and config
      Current location is usb
t.    Switch timeserver between ntpd and chronyd
      Currently using
      Config location:
r.    Restart
If I try menu item 1, which is "Update timeserver stats now", I get this error: Error: near line 2: in prepare, near ",": syntax error (1) .
It was working before 386.7 . Is it possible the shell version changed and that changed the behavior?
On AX88U no issue found.
Running OK for me on an AC68U, maybe run a fsck on your drive?
