Continuation from previous thread. It would not let me respond because of the 6 month rule.
www.snbforums.com
Thanks, it's good to know I'm not alone with this issue. I run a script as a daily cron job that calls this script, so I really do not know if it failed unless I log in and look for it. When it fails, it seems it just quits, so maybe there is something under the hood that is stopping the script from finishing, like a resource conflict, USB maybe, or a file that is being accessed by another process, which is why I asked if there is a way to track the execution to look for any of these kinds of conflicts.
NVRAM - [Release] NVRAM Save/Restore Utility
Utility to save/restore NVRAM values and the jffs partition on Asuswrt-Merlin firmware. Installation and usage instructions are available on the NVRAM Save/Restore Utility GitHub page with additional instructions in the project QuickStart.txt file. Requirements A properly formatted USB drive...
Possibly, but maybe there is something else going on?
I only ever run my NVRAM backups manually using your utility and I’ve seen it fail maybe 3-4 times over a year or so of doing them roughly weekly. My drive is a 250GB Samsung EVO860 SSD inside a UGreen SATA-to-USB 3.0 2.5” case, which has been utterly reliable for everything else in terms of scripts and Entware, which is all it gets used for.
So I’m not ruling out it COULD be causing your script to fail occasionally but all the evidence points to the contrary? So for me it’s a minor annoyance, but I just run it again
BTW thanks for your script(s) and all your work here, it is much appreciated!
I know. But I've tried several different flash drives. The NVRAM User Save Utility script occasionally fails with all that I've tried including the latest, new Samsung drive.@TonyK132 a new flash drive does not mean it is a 'good' flash drive.![]()
