Nvram usuage
Kaz
Hi, I have noticed that on my AC68U, the NVRam usage is high, how do I clear up this
dave14305
Part of the Furniture
It's not really high based on what it's needed for. If you reset to factory defaults and configure things from scratch, that would show you the minimum nvram you should expect to consume. I think you're fine where it's at now.
You can show your top 20 nvram variable sizes with this command at the SSH prompt:
Bash:
nvram show 2>/dev/null | awk '{print length(), $0 | "sort -n -r"}' | cut -d"=" -f 1 | head -n 20
This is mine if it makes you feel any better:
  • Like
Reactions: Kaz
RMerlin
Asuswrt-Merlin dev
51 KB is actually very low for an RT-AC68U. My own development router is sitting at about 62 KB used.
