Odd blocking issue on outgoing VPN
Revelstone77
I am experiencing a very odd issue. When using my company laptop, I have to connect to them using Cisco AnyConnect VPN. Connecting is no problem, but i cant access some of the resources. Some work, and others dont. I moved the laptop and plugged directly into my ATT gateway, bypassing my Asus AC86U router and everything works perfectly. I can access everything. I was experiencing the same issues on my AC87U before upgrading. Router confiig was created new when I installed the 86U. Connect back through my router and I am back to some things work and others dont. Doesnt matter if I connect wired or wireless. I disabled AiProtection and rebooted the router, but no help. I'm not doing anything fancy, that i know of, that could cause an issue. Anybody have any ideas? I can post anything that might be needed.
What's the MTU you can reach with and without VPN on?
Do you have a PPoE on Asus?
It's been a while since I used AnyConnect...there was a setting in ASA&Concentrator to deal with packets with Don't Fragment bit set.
no PPoE
Not sure how to check MTU. in windows it's fixed to 1500 from what i remember. Couldnt change it anyway, those things are locked down by the company. wondering if enabling Jumbo frames might help
