[Official] RT-AC56U Firmware version 3.0.0.4.378.9135
fedez16
ASUS RT-AC56U Firmware version 3.0.0.4.378.9135
- Release Note -
Security Fixes
- Updated TrendMicro security engine.
- Fixed CVE-2015-6949 buffer overflow issue, special thanks for Elvis Collado at Praetorian.
- Fixed Web server Accept-Language buffer overflow, special thanks for Elvis Collado at DVLabs.
- Fixed Web server URL handler buffer overflow, special thanks for Elvis Collado at DVLabs.
- Enhanced router login password and wireless password(WPA2) strength check method to against brute-force attack.
- Reject administrator to set too easy to guess login and wireless password to avoid brute-force attack.
New Features
- Time scheduling, Web & App filter, Wireless MAC filter client drop down menu can show offline devices.
Modifications
- Added Meo and Movistar ISP profile.
- Adjusted Guest network mac filter maximum client number to 16
- Allow paste password on login page to fulfil some password management softwares requirement.
- Show current control channel while value is auto.
- Bandwidth limiter can accept decimal point.
- Unnecessary to reboot router after set allow only spcified IP address to enter GUI.
- Adaptive QoS can now be enabled without assigned upload/ download bandwidth.
Fixes
- Fixed setup wizard IE11 compatibility issue.
- Fixed Adaptive QoS game mode GUI issue.
- Fixed Traffic Analyzer GUI issue.
- Fixed OpenVPN connection status display error.
http://support.asus.com/download.as...C56U&p=11&s=2&os=30&hashedid=ejvcVtFQNPxjVH5w
I have an RT-AC56R running the previous version. When I check for updates the UI says my router is running the latest version. Shouldn't the router be installing this version instead? I was under the impression the RT-AC56U and RT-AC56R were identical. Thanks.
Asus didn't update their liveupdate server.
