[Official] RT-AC56U Firmware version 3.0.0.4.378.9313
charlie2alpha
RT-AC56U Firmware version 3.0.0.4.378.9135
Release notes:
Security Improvement
- Fixed User-Agent buffer overflow. Special thanks for Hubert's contribution.
- Fixed null ptr dereference in https issue. Special thanks for Anthony's contribution
- Fixed buffer overflow issues.
- Modified brute-force protection mechanism in router login page.
- Fixed malicious site block related issues.
New Feature
Support ASUS router app which make it very easy to monitor and manage route status and client devices and more.
Search ASUS Router in google play or go the following URL
https://play.google.com/store/apps/details?id=com.asus.aihome
iOS app coming soon.
Bug Fixes
- Fixed httpd crash issue. Special thanks for Merlin's contribution.
- Fixed blank web page when clients number over 100.
- Fixed Network map client list related issues.
- Fixed firmware login issue when connect to router by OpenVPN.
- Add reboot scheduler in Administration --> System
- Fixed warning page showing issue when only enable the HTTPS authentication.
- Fixed the slow UI issue when enabled Bandwidth limiter.
- Fixed repeated mDNSNetMonitor message in system log when there is a Apple TV in LAN.
- Fixed IPv6 firewall UI issue.
- Fixed UI issue when enable monopoly mode in printer setting.
Note: There is no source code release yet as of the time of this post.
The 378.9313 release seems like a bug fixing version with the only new feature being the support of the new ASUS Router app. No sources yet so third party firmware developers can't update their code yet.
The source code is now available in Asus' website.
Sent from my Nexus 9 using Tapatalk
I did not install the previous release due to many reported bugs with it. Has anyone with an AC56U installed this version and if so are they're any problems. When I do the check firmware procedure via the UI it says my router has the latest version which actually isn't accurate but it always says that, LOL. Thanks.
I have not noticed any issues with 9313 firmware.
Thanks for letting me know. I've actually never updated the firmware since I got my router in April. Will I need to press the restart button after installing and then lose all my settings? Thanks
Finally got around to installing 9313 and it was seamless..the router came up immediately and I didn't need to reset. Installed the mobile app, logged into the router and all is good.
