RocketJSquirrel
[Apologies for this repeat post. My original post accidentally got deleted before I got any replies.]
The GUI on the RT-N66U which handles the Roaming Assistant constrains the signal strength threshold for dropping clients to the range of -90 to -70 dB RSSI .
I would like to set the threshold to -68 because of the actual signal levels in my house.
Is it OK to use the command line to nvram set wl_user_rssi to a number greater than -70, or will that break something? And do I need to set wl0_user_rssi as well?
This is an RT-N66u running 3.0.0.4.374.39_0-em.
