Hello,
I am using Asus RT-AC68U with 386_7.2 firmware. I experienced strange but very annoying issue. Sometimes all my devices(computers/phones,etc.) lost the internet connection and cannot get ip from the router. I also cannot login to router from the computer with static ip address(I use static ip address for desktop PCs). Cannot ping the router as well. After spending some time to troubleshoot, I found the problem is on one computer that went on sleep. If I disconnect the ethernet cable from it, the home network restored, everything works again. I turned on that computer, connect back the cable, no issue at all. I then put it to sleep, the home network is still working fine.
Some weeks later, the same issue occurred again but causing by another computer. Same method(disconnect ethernet cable, turn on computer and reconnect the cable back) to solve the network outage.
It seems a random issue but it all happened on computers with wired ethernet connection. The computer is either at sleep, off, or non-responsive state when it is causing network issue.
It happened on previous version of merlin firmware as well.
I don't understand why a single device could cause entire network problem when there is no physical issue i.e. wire short-circuit/grounded/voltage drop/network adapter failure. To me it is more like software issue because Asus router stop assigning IP addresses.
Any advice? Thanks
Any advice? Thanks
