Greetings all
Thanks for looking into this post.
My setup is currently as such...
Fibre modem- >
mikrotik routerboard 2100 (Google DNS, static IP 192.168.0.1, DHCP enabled) ->
LAN ->
2 x mikrotik APs (auto DNS from gateway, static IP's 192.168.0.157 AND 192.168.0.179, Private connections, DHCP enabled 192.168.88.1) to be used as a public AP
I need to apply OpenDNS IP's to both wAPs only, so when public use it they are filtered off dodgy websites.
How can I do this without affecting the static Google DNS setup on the main mikrotik router (which LAN PCs are using its DNS servers from Google).
I just want to know the rational on how to do this.
Hope this makes sense?
monty
Fibre modem- >
LAN ->
monty
