openssl
bigcid10
I doing this on the fly because I'm really unsure about what I'm doing
I'm trying to setup this openvpn client on my router so here's my problem so far
I got the openvpn client for windows
but it didn't come with easy-rsa so I hunted that down
and followed the readme
but when I got to the command "build-ca" it said that openssl was reconized as
a command of that sort
can some give me a simpler walkthrough or give me some direction
thank you
I try and run the command "setuprsa.sh /mnt/sdb1"
and it gives me the error " cp: can't preserve permissions of '/mnt/sdb1/easy-rsa/sign-req': Operation not permitted " and won't copy the files to the flash drive
also every time it tries to write the crt an key info on the flash drive it say "Using configuration from /mnt/sdb1/easy-rsa/openssl-1.0.0.cnf
/mnt/sdb1/easy-rsa/keys/index.txt: No such file or directory
unable to open '/mnt/sdb1/easy-rsa/keys/index.txt' "
thanks
thanks
Probably means that your disk isn't formatted as ext2/ext3. In that case create a directory inside /tmp, and do everything from that directory. Once done, copy the resulting files to your USB disk.
ok,it was formatted in fat
I 'll reformat and try it again
I have a Linux laptop ,I'll do it on that
is ext4 ok?
when I did that the drive in the router says unmounted
is ext4 ok?
Ext4 is not supported. The kernel used by this router is too old.
how can I reformat it into ext3
my linux laptop doesn't give me an otion for ext3
only linux swap,linux,or ext4
thanks
thanks
"mkfs -t ext3 /dev/sdxx" through a terminal session.
OK,I got the server up and running on the router(yea!)
but now I can't figure out to get the client key and profile setup on either my android or my pc(win8)
thanks for your patience
