Hi. First things first, want to thank Merlin for the great work on the firmware - really appreciate the hard work that goes into this project
So, I've upgraded the firmware on my AC87U to 380.65, which comes with OpenVPN 2.4. So now I'm trying to set up a server that uses Elliptic Curve Cryptography (ECC) with Elliptic curve Diffie–Hellman (ECDH) key exchange, which is supposed to be both more secure and more efficient. As far as I'm aware, both are built-in to OpenVPN 2.4.
Now I''ve followed the instructions from the OpenVPN and Easy-RSA How-To's to create a CA and PKI using ECC, but when it comes to getting these to work with the AC87U server, I'm having some trouble. There doesn't seem to be an option for any of the ECC curves in the Auth digest section, which I believe is what causing me to have problems connecting. Even using the custom field has yielded no results.
So my question is this. Does the OpenVPN version included with 380.65 support Elliptic Curve? And if so, could anyone help me with setting up a server using ECC on my AC87U? Any help would be appreciated. Thanks
