OpenVPN Certificate Authority field more than 3499 char limit?
CityRaccoon
Is it possible to set up OpenVPN if you need to add a Certificate Authority that exceeds the 3499 character limit? When I import the .ovpn file, it truncates at 3499 and I get an error. The cause of the error is clear when you click on "Content modification of Keys & Certificates." - you can see the Certificate Authority has been truncated at 3499 chars.
I have tried manually editing /jffs/openvpn/vpn_crt_client1_ca to include the full certificate text which is greater than 3499 characters, and then starting up the VPN using the web UI, but that doesn't seem to work. It seems as though it hasn't picked up the updated certificate.
I am trying to set up Mullvad VPN on 380.70 (which I am still on b/c it's a RT-AC66R)
[Edit - is this improved/resolved in more recent versions than 380.70?]
