Openvpn (client) and port forwarding.
mgs
Folks,
For over a long time I cannot get port forwarding work with openvpn on my RT-AC87u. If PPTP is engaged then all works but once openvpn is up all forwarding rules don't work until I write something like
iptables -t nat -A PREROUTING -p tcp -i tun<num_config> --dport <incoming_port> -j DNAT --to-destination <dst_client:dst_port>.
Is there an elegant way to avoid such an issue (seting all the rules manually upon starting/shutdown openvpn is not an option) or may be I'm doing something wrong?
If it's a bug can it be fixed?
First question is no longer important: solved by creating user-script:
/jffs/scripts/openvpn-event
#!/bin/sh
interface=$1
if [ "$script_type" = "down" ] ; then
iptables -t nat -D PREROUTING -i $interface -j VSERVER
fi
if [ "$script_type" = "up" ] ; then
iptables -t nat -A PREROUTING -i $interface -j VSERVER
fi
Second one still remains.
Uhm, I don't see two questions above? But maybe it's just me? :D
@mgs I still see it as one/fixed. :)
Well I do believe that it has to work the same way as PPTP i.e. without any additional clutch. But maybe it's just me ;).
