OpenVPN Client block all connections
Mightyous
Hi guys,
my new Asus RT-AC68U with Merlin-Image, block all internet connections.
Without VPN all is working. Open .ca file in a unix editor and paste it under "Certificate Authority". Was it the right place?
Here´s my log file
Oct 11 13:55:46 rc_service: httpd 478:notify_rc start_vpnclient2
Oct 11 13:55:46 kernel: tun: Universal TUN/TAP device driver, 1.6
Oct 11 13:55:46 kernel: tun: (C) 1999-2004 Max Krasnyansky <[email protected]>
Oct 11 13:55:46 openvpn[2674]: OpenVPN 2.3.7 arm-unknown-linux-gnu [SSL (OpenSSL)] [LZO] [EPOLL] [MH] [IPv6] built on Jul 16 2015
Oct 11 13:55:46 openvpn[2674]: library versions: OpenSSL 1.0.2d 9 Jul 2015, LZO 2.08
Oct 11 13:55:46 openvpn[2675]: WARNING: No server certificate verification method has been enabled. See http://openvpn.net/howto.html#mitm for more info.
Oct 11 13:55:46 openvpn[2675]: NOTE: the current --script-security setting may allow this configuration to call user-defined scripts
Oct 11 13:55:46 openvpn[2675]: Socket Buffers: R=[122880->131072] S=[122880->131072]
Oct 11 13:55:46 openvpn[2675]: UDPv4 link local: [undef]
Oct 11 13:55:46 openvpn[2675]: UDPv4 link remote: [AF_INET]176.10.100.2:1194
Oct 11 13:55:46 openvpn[2675]: TLS: Initial packet from [AF_INET]176.10.100.2:1194, sid=a98df10b 8c30cbb8
Oct 11 13:55:46 openvpn[2675]: WARNING: this configuration may cache passwords in memory -- use the auth-nocache option to prevent this
Oct 11 13:55:47 openvpn[2675]: VERIFY OK: depth=1, C=ZZ, ST=ZZ, L=ZZ, O=n/a, OU=MyOrganizationalUnit, CN=NA, name=EasyRSA, emailAddress=[email protected]
Oct 11 13:55:47 openvpn[2675]: VERIFY OK: depth=0, C=ZZ, ST=ZZ, L=ZZ, O=n/a, OU=MyOrganizationalUnit, CN=pmvpn3, name=EasyRSA, emailAddress=[email protected]
Oct 11 13:55:47 openvpn[2675]: Data Channel Encrypt: Cipher 'AES-128-CBC' initialized with 128 bit key
Oct 11 13:55:47 openvpn[2675]: Data Channel Encrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
Oct 11 13:55:47 openvpn[2675]: Data Channel Decrypt: Cipher 'AES-128-CBC' initialized with 128 bit key
Oct 11 13:55:47 openvpn[2675]: Data Channel Decrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
Oct 11 13:55:47 openvpn[2675]: Control Channel: TLSv1, cipher TLSv1/SSLv3 DHE-RSA-AES256-SHA, 2048 bit RSA
Oct 11 13:55:47 openvpn[2675]: [pmvpn3] Peer Connection Initiated with [AF_INET]176.10.100.2:1194
Oct 11 13:55:50 openvpn[2675]: SENT CONTROL [pmvpn3]: 'PUSH_REQUEST' (status=1)
Oct 11 13:55:50 openvpn[2675]: PUSH: Received control message: 'PUSH_REPLY,redirect-gateway,dhcp-option DNS 8.8.4.4,dhcp-option DNS 8.8.8.8,dhcp-option WINS 8.8.8.8,dhcp-option WINS 8.8.4.4,route 10.8.0.1,topology net30,ping 10,ping-restart 60,ifconfig 10.8.0.102 10.8.0.101'
Oct 11 13:55:50 openvpn[2675]: OPTIONS IMPORT: timers and/or timeouts modified
Oct 11 13:55:50 openvpn[2675]: OPTIONS IMPORT: --ifconfig/up options modified
Oct 11 13:55:50 openvpn[2675]: OPTIONS IMPORT: route options modified
Oct 11 13:55:50 openvpn[2675]: OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified
Oct 11 13:55:50 openvpn[2675]: TUN/TAP device tun12 opened
Oct 11 13:55:50 openvpn[2675]: TUN/TAP TX queue length set to 100
Oct 11 13:55:50 openvpn[2675]: do_ifconfig, tt->ipv6=0, tt->did_ifconfig_ipv6_setup=0
Oct 11 13:55:50 openvpn[2675]: /usr/sbin/ip link set dev tun12 up mtu 1500
Oct 11 13:55:50 openvpn[2675]: /usr/sbin/ip addr add dev tun12 local 10.8.0.102 peer 10.8.0.101
Oct 11 13:55:53 openvpn[2675]: /usr/sbin/ip route add 176.10.100.2/32 via 192.168.0.1
Oct 11 13:55:53 openvpn[2675]: /usr/sbin/ip route del 0.0.0.0/0
Oct 11 13:55:53 openvpn[2675]: /usr/sbin/ip route add 0.0.0.0/0 via 10.8.0.101
Oct 11 13:55:53 openvpn[2675]: /usr/sbin/ip route add 10.8.0.1/32 via 10.8.0.101
Oct 11 13:55:53 openvpn-routing: Skipping, client 2 not in routing policy mode
Oct 11 13:55:53 openvpn[2675]: Initialization Sequence Completed
Many tunnel providers force you to use specific DNS servers, in an attempt to prevent leakage. Set DNS setting to Strict on your OpenVPN client page.
that doesn´t help
Once connected are you able to ping 8.8.8.8?
Is the Redirect internet traffic option set to no or something else?
