As I understand from running the last several Merlin F/W iterations there are 5 OpenVPN clients that can be configured at any given time.
Since I never ran the original Asus WRT firmware I'm uncertain if that's an Asus or Merlin feature.
However, the point I'm asking input for is that out of the 5 clients only the 1st one has the "Rules for routing client traffic through the tunnel (Max Limit : 100)" section. The other 4 are on an 'all OR nothing' basis.
Would it be possible to have that option (to only route traffic from certain end-points) through that VPN client as a filter on each of the remaining 4 VPN clients? (I also understand that in many use cases the simple answer would be to just initiate the VPN through the end-point itself.)
