OpenVPN default traffic through VPN, however select clients for WAN traffic
madfusker
I have the opposite problem of every post I find on here. Most people want their NAS to be the only thing on the VPN whereas I want everything but the NAS to be there. If I set Redirect Internet Traffic to "policy rules", then I must select EVERY client IP and add a rule that says VPN or WAN. The problem is when a DCHP client connects it will not go through VPN. If I select All traffic, there is no way to set the exception IP for the NAS. Anyone know how to make the default VPN, but then specify exceptions such as a NAS? Search only turns up the opposite of this.
Thanks,
-MH
Thanks,
-MH
There are several replies in the main 'Selective Routing' and the 'OPENVPN Policy Routing' threads (but I found it is best to use Google to specify a search in this forum).
So you need the following RPDB Policy rules (replace 192.168.1 with your subnet if required)
192.168.1.0/24   0.0.0.0   VPN (all LAN devices)
192.168.1.xxx    0.0.0.0   WAN (your NAS)
192.168.1.1      0.0.0.0   WAN (so router isn't routed via VPN unless of course you need this)
I thought I had tried that, but did so again and it works. Thanks a lot! I also found the 'Selective Routing' and the 'OPENVPN Policy Routing' threads which are a great help. Huge thumbs up to Merlin for this selective routing feature!
