Hi Merlin, my OpenVpn is not startup after Router reconnect.
I see in the logfile 2 scripts at the same time openvpn shutdown und startup.
I think the startup after reconnect is to quick?
My log:
My log:
Oct 13 07:33:03 pppd[559]: LCP terminated by peer
Oct 13 07:33:03 pppd[559]: Connect time 1440.1 minutes.
Oct 13 07:33:03 pppd[559]: Sent 45479565 bytes, received 817642663 bytes.
Oct 13 07:33:03 dnsmasq[581]: read /etc/hosts - 3 addresses
Oct 13 07:33:03 dnsmasq-dhcp[581]: read /etc/ethers - 4 addresses
Oct 13 07:33:03 dnsmasq[581]: using nameserver x.x.x.143#53
Oct 13 07:33:03 dnsmasq[581]: using nameserver x.x.x.142#53
Oct 13 07:33:04 WAN Connection: Fail to connect with some issues.
Oct 13 07:33:04 notify_rc : stop_nat_rules
Oct 13 07:33:04 stop_nat_rules: apply the redirect_rules!
Oct 13 07:33:05 openvpn[1230]: write UDPv4 []: Network is unreachable (code=128)
Oct 13 07:33:06 pppd[559]: Connection terminated.
Oct 13 07:33:06 pppd[559]: Sent PADT
Oct 13 07:33:06 pppd[559]: Modem hangup
Oct 13 07:33:15 openvpn[1230]: write UDPv4 []: Network is unreachable (code=128)
Oct 13 07:33:16 pppd[559]: PPP session is 1411 (0x583)
Oct 13 07:33:16 pppd[559]: Connected to 00:xx:xx:xx:xx:xx via interface eth0
Oct 13 07:33:16 pppd[559]: Using interface ppp0
Oct 13 07:33:16 pppd[559]: Connect: ppp0 <--> eth0
Oct 13 07:33:17 pppd[559]: CHAP authentication succeeded
Oct 13 07:33:17 pppd[559]: peer from calling number 00:xx:xx:xx:xx:xx authorized
Oct 13 07:33:17 pppd[559]: local IP address x.x.x.x
Oct 13 07:33:17 pppd[559]: remote IP address x.x.x.x
Oct 13 07:33:17 pppd[559]: primary DNS address x.x.x.x
Oct 13 07:33:17 pppd[559]: secondary DNS address x.x.x.x
Oct 13 07:33:17 dnsmasq[581]: read /etc/hosts - 3 addresses
Oct 13 07:33:17 dnsmasq-dhcp[581]: read /etc/ethers - 4 addresses
Oct 13 07:33:17 dnsmasq[581]: using nameserver x.x.x.x#53
Oct 13 07:33:17 notify_rc : start_nat_rules
Oct 13 07:33:17 start_nat_rules: apply the nat_rules!
Oct 13 07:33:18 notify_rc : stop_upnp
Oct 13 07:33:18 miniupnpd[1236]: received signal 15, good-bye
Oct 13 07:33:18 notify_rc : start_upnp
Oct 13 07:33:18 syslog: SNet version started
Oct 13 07:33:18 miniupnpd[4708]: HTTP listening on port 42327
Oct 13 07:33:18 miniupnpd[4708]: Listening for NAT-PMP traffic on port 5351
Oct 13 07:33:19 WAN Connection: WAN was restored.
Oct 13 07:33:19 notify_rc : start_nat_rules
Oct 13 07:33:19 notify_rc : start_apps_update
Oct 13 07:33:19 rc_service: start_apps_update is waitting start_nat_rules...
Oct 13 07:33:28 ddns update: connected to members.dyndns.org (204.13.248.111) on port 80.
Oct 13 07:33:28 ddns update: error recv()ing reply: Connection reset by peer
Oct 13 07:33:28 ddns update: server output:
Oct 13 07:33:28 ddns update: strange server response, are you connecting to the right server?
***Oct 13 07:33:28 notify_rc : stop_vpnclient1
***Oct 13 07:33:28 notify_rc : start_vpnclient1
***Oct 13 07:33:28 rc_service: start_vpnclient1 is waitting stop_vpnclient1...
***Oct 13 07:33:44 rc_service: skip the event: start_vpnclient1.
Oct 13 07:33:53 openvpn[1230]: TLS: tls_process: killed expiring key
Oct 13 07:33:54 openvpn[1230]: TLS: soft reset sec=0 bytes=36855/0 pkts=702/0
Oct 13 07:33:58 openvpn[1230]: event_wait : Interrupted system call (code=4)
Oct 13 07:33:58 openvpn[1230]: TCP/UDP: Closing socket
Oct 13 07:33:58 openvpn[1230]: /sbin/route del -net 10.14.0.0 netmask 255.255.0.0
Oct 13 07:33:58 openvpn[1230]: /sbin/route del -net 10.12.0.0 netmask 255.255.0.0
Oct 13 07:33:58 openvpn[1230]: /sbin/route del -net 10.11.0.0 netmask 255.255.0.0
Oct 13 07:33:58 openvpn[1230]: /sbin/route del -net 10.10.0.0 netmask 255.255.0.0
Oct 13 07:33:58 openvpn[1230]: /sbin/route del -net 10.1.1.0 netmask 255.255.255.0
Oct 13 07:33:58 openvpn[1230]: Closing TUN/TAP interface
Oct 13 07:33:58 openvpn[1230]: /sbin/ifconfig tun11 0.0.0.0
Oct 13 07:33:58 openvpn[1230]: updown.sh tun11 1500 1542 10.1.1.6 10.1.1.5 init
Oct 13 07:33:58 openvpn[1230]: SIGTERM[hard,] received, process exiting
