openvpn-event script works with vpnclient1-route-up and vpnserver2-route-down. Can it work with vpnclient1-ipchange?
What would be the best way of dealing with this? It seems as though PIA does not disconnect the client vpn. They just change the remote ip. Which causes some local scripts to fail when using routes or port forwarding.
openvpn has an -ipchange option. "Executed after connection authentication, or remote IP address change."
