I've recently upgraded to the new release. I am having some major issues.
OpenVPN does not appear to work anymore.
I am using the exact same Certificates etc...I can connect to the VPN but cannot do anything with it i.e. none of the hosts on my LAN are reachable.
In looking at the client logs I can see NET WiFI:NotReachable
What has changed that would cause this to happen? Hopefully there is a simple solution. Just a note, I have been using VPN for well over a year without a single hitch.
Edit:
The problem seems to be isolated to using TCP with the option of directing clients to redirect traffic. If this option is done on UDP than there is no issue.
Dave
Edit:
Dave
