OpenVPN on Mullvad: No Access from outside
SilentEYE
Hello Merlin Community,
i am using an ASUS AX-86U with Merlin 386.7_2 and set up an Mullvad VPN Client. My goal is to use some SmartDevices like my Roborock S6 Cleaner (connected on a Guest Network) through that VPN Tunnel, but the devices aren't accessible over the internet after connecting to the VPN.
If I route my Smartphone over the VPN, the internet is working well and my IP address is correct. The Merlin Menu shows a working VPN connection too.
- Using VPN Director policy rules.
- My Mullvad config:
resolv-retry infinite
remote-cert-tls server
ping 10
ping-restart 60
sndbuf 524288
rcvbuf 524288
cipher AES-256-CBC
tls-cipher TLS-DHE-RSA-WITH-AES-256-GCM-SHA384:TLS-DHE-RSA-WITH-AES-256-CBC-SHA
tun-ipv6
fast-io
remote-random
comp-lzo no
What am I doing wrong? How can I provide more information for you guys?
@Gary_Dexter
Thank your for the hint. I will try some other smart devices, to see, if its VPN related.
How does the Vacuum cleaner know, that it is connected to a VPN?
