OpenVPN & RADIUS server
davidology
This is probably a dumb question, but is there any way to setup the OpenVPN server to use the RADIUS server as username/password authentication instead of the table on the OpenVPN Server tab? It doesn't appear to be possible, but thought I should ask as it would be kind of nice to be able to use that rather than create another set of users.
Thanks!
Not out of the box. OpenVPN does not support authenticating against a Radius server, you would need to compile an external plugin for that.
