Solved Openvpn server /client combination Yazfi issue
JoGi
I recently started using yazfi to route / link a guest network with vpnclient.
this works great. :)
The only thing that strikes me now is that my existing Openvpn server is no longer working properly.
If I make a VPN connection on my phone / PC, with vpn server, this works fine.
but when I look at IP + location through a web browser, it shows my current IP location, instead of the location of the (vpn) router.
note:
before,
without using or configuration yazfi (guest network <> vpnclient), my vpn server worked fine?
I hope that someone has a idea what this could be or misconfigured at my side?
YazFi doesn't change anything with VPN Server configuration. Are you connecting from a separate network, and not a guest network? Double check the VPN Server configuration is set to use Internet
I am so ashamed :-(. , the hint with internet settings was the solution.
sorry for the "stupid" question
thank you very much
I'll close this thread
