infantryman
Good day all!
On my router RT-AC68U (using ASUSWRT-Merlin), I've setup an OpenVPN server which is working fine with my OpenVPN clients (2 x Android cell phones). I also wanted the router to be an OpenVPN client using a PureVPN server which works fine as well. Also, I am using No-IP as DDNS. Here is the issue : If the router OpenVPN server and OpenVPN client (using PureVPN) are running together at the same time, I can't connect the server's OpenVPN clients (2 x Android cell phone) to the router OpenVPN server. (Just so you know, the OpenVPN server status is ''running'' and the OpenVPN client using PureVPN is ''connected'' when I try to connect the cell phones to the router OpenVPN server).Finally, I can't remotely access my IPCams anymore (as it used to work BEFORE I started to use the PureVPN server through my OpenVPN client). I am using the DDNS address with the port numbers to remote the IPCams.
Anyone has an idea to solve this problem, please?
http://www.hostingpics.net/viewer.php?id=763205Untitled.jpg
