Emiljan Haxhi
Hi Guys,
I have a odd issue, I have OpenVPN server running on my RT-AC68U (Asuswrt-Merlin v384.9) and I am having difficulty connecting to a downstream router.
On one of the LAN ports on my AC68U has a Ubiquity router (Edgerouter X) configured with 4 different networks (192.168.10.0/24, 192.168.20.0/24, 192.168.30.0/24, 192.168.40.0/24) via eth1-4, eth0 is used for the IP of the LAN (192.168.1.200)
My AC68U network is 192.168.1.0/24
On my AC68U I have 4 static routes added for the Edgerouter X networks and I am able to reach them while connected via WIFI or Ethernet.
My VPN network is 192.168.3.0/24, when i connect I get a IP of 192.168.3.2, gateway 192.168.3.1. I am able to connect to devices on the 192.168.1.0/24 network, but when i try to access any of the devices on the edgerouter-x networks, connection fails. I have tried pinging devices on all 4 networks with no response. Traceroute fails as well.
These are my routing tables for the:
Client connected to the VPN (Ubuntu 18.04)
default _gateway 0.0.0.0 UG 0 0 0 enp0s3
10.0.2.0 0.0.0.0 255.255.255.0 U 0 0 0 enp0s3
link-local 0.0.0.0 255.255.0.0 U 0 0 0 enp0s3
192.168.1.0 192.168.3.1 255.255.255.0 UG 0 0 0 tun0
192.168.3.0 0.0.0.0 255.255.255.0 U 0 0 0 tun0
192.168.10.0 192.168.3.1 255.255.255.0 UG 0 0 0 tun0
192.168.20.0 192.168.3.1 255.255.255.0 UG 0 0 0 tun0
192.168.30.0 192.168.3.1 255.255.255.0 UG 0 0 0 tun0
192.168.40.0 192.168.3.1 255.255.255.0 UG 0 0 0 tun0
RT-AC68U (hidden my public IP)
Destination Gateway Genmask Flags MSS Window irtt Iface
PUBLICIP * 255.255.255.255 UH 0 0 0 vlan2
192.168.20.0 edgerouterx 255.255.255.0 UG 0 0 0 br0
192.168.3.0 * 255.255.255.0 U 0 0 0 tun22
192.168.2.0 * 255.255.255.0 U 0 0 0 tun21
192.168.1.0 * 255.255.255.0 U 0 0 0 br0
68.40.138.0 * 255.255.255.0 U 0 0 0 vlan2
192.168.30.0 edgerouterx 255.255.255.0 UG 0 0 0 br0
192.168.10.0 edgerouterx 255.255.255.0 UG 0 0 0 br0
192.168.40.0 edgerouterx 255.255.255.0 UG 0 0 0 br0
127.0.0.0 * 255.0.0.0 U 0 0 0 lo
default PUBLICIP 0.0.0.0 UG 0 0 0 vlan2
In this case edgerouterx is 192.168.1.200
