Hello guys, I have configured a OpenVPN on my Asus 86U and I’m quite happy with it.
Anyhow I think I need some explanation (I’m a noob) about how this VPN works in an environment where my IP is NAT/PAT by the ISP.
I try to better explain what I cannot understand:
· My 86U manage a VPN with a specific UDP port on a private IP that is assigned by the ISP to my router. This private IP is later on NAT/PAT by the ISP to a public IP (that, as far as I have understood, it is unknown at the router)
· Only the private IP is associated with DDNS service
· My mobile (the host where I need to connect at the VPN), with OpenVPN app installed, connects to the VPN using the DDNS private IP information and the UDP port assigned to the VPN by the 86U (according to client.ovpn file created by the router)
The question is: who is telling the route from the public IP of my mobile to the public IP associated to the 86U private IP ? And viceversa ?
Surely I’ve not understood this NAT/PAT process and I'm aking a wrong question but , hopefully, someone of you can explain me how the process works ... because the process works very well
