OpenVPN with static key for all local network clients
Andreas Gohr
I'm trying to setup my router running the AsusWRT-Merlin firmware as an OpenVPN client. The VPN is a simple static key based one to my root server. The goal is to have all traffic from my local net to be routed through the VPN.
Under VPN -> OpenVPN Client I set up the configuration for connecting to my server using the local/remote endpoints of 192.168.42.2/192.168.42.1 and set Redirect Internet Traffic to All Traffic. The VPN is up and running, but my traffic is not routed through the VPN.
System Log - Routing Table shows the following:
Destination        Gateway          Genmask            Flags    Metric    Ref    Use  Iface
192.168.42.1       *                255.255.255.255    UH       0         0      0    tun11
100.74.255.254     *                255.255.255.255    UH       0         0      0    WAN
192.168.1.0        *                255.255.255.0      U        0         0      0    LAN
100.74.192.0       *                255.255.192.0      U        0         0      0    WAN
default            100.74.255.254   0.0.0.0            UG       0         0      0    WAN
As you can see the VPN TUN interface is up correctly, but all traffic is still routed through 100.74.255.254 which is my current cable modem IP.
Question is how/where to configure that all local network traffic goes through the VPN?
Screenshots of my settings can be seen here: https://imgur.com/a/ci6QO
I tried that too, but it changes absolutely nothing. Routes are the same and traffic still does not go through the VPN.
