optimized settings for wifi on RT-N18U router
cork
All the devices connected to my network via LAN the speed is ok.
The wifi is sluggish I have multiple anndroid devices connecting at the same time what are the best setting in the router for this
my current settings screen shot attached
A wifi scanner is needed. There are several free ones for Android if you use it. My favorite is Wifi Analyzer. It's Ad-free and works well.
A few other comments I have on your settings are:
1) I suggest making your SSID more unique than "ASUS". If you are located in a location with many other wireless networks, there may be other people using the same SSID.
2) If all your devices are transmitting in n-mode (and not b or g), then I suggest setting the Wireless Mode to n-only.
3) For n-only conditions, in the advanced settings I suggest disabling Tx bursting. That is only for g-devices only.
