I recently replaced my Arris SB6190 modem with a Netgear CM600 due to the well publicized issues with jitter/latency on Intel's Puma 6 chipset that the SB6190 uses.
One of the tools used to help diagnose this issue is here: http://www.dslreports.com/tools/puma6
Its essentially pinging a server on the internet but instead of using ICMP its using TCP. This is because some internet routers/etc block ICMP, or lower the priority of ICMP in favor of TCP/UDP. So a TCP test is more accurate.
Anyways, if I am cabled directly into my Netgear CM600 modem I experience almost no jitter. For example, everything is tightly clustered around 35ms in this test:
Compare that to test when my mac mini is cabled into the Orbi:
The response time distribution isn't so neatly packed around 35ms - many responses are 2x that!
Things I have tried:
https://community.netgear.com/t5/Orbi/Orbi-latency-peaks-every-10s/m-p/1200477
- I downgraded router & both satellites to V1.4.0.18 from V1.4.0.34 - didn't help
- I made the mac mini the only client on the Orbi. I did this by removing power from both satellites and disabling both the 2.4Ghz and 5Ghz radios on the router in the Advanced Wireless settings. I also unplugged a switch with more wired devices from the router. At this point my mac mini was the ONLY client listed in Orbi's management inteface - didn't help jitter issues at all.
