Hello, first of all thank you Merlin for your software, dedication and time spent.
I've been using your 178.15 version for some days (I use wireless for a cell phone through 2.4GHZ and I use ethernet for my pc, sitting just a couple of feet next to the router).
Last night while trying to watch some videos from youtube on my pc I noticed that halfway through the video it stopped playing, assumed It was an error, reloaded and tried to play from the part where it stopped working, this went on for a couple of times, didn't pay much attention to it.
Today I went back to doing the same and I noticed the same behaviour; I decided to check the Asus system log and found that packets were being dropped. I tried rebooting the router and also disabling the asus firewall just to check but the problem remained; (This didn't happen anymore when I tried skipping the router and plugging the ethernet directly the cable modem to the pc for some reason)
I'm really sorry since I've been a wired user most of my life and don't have much experience with this so I don't know what kind of information I would need in order to be easier to help me identify the problem or what's causing it, or any additional tests or proccedures I should perform, so please tell me if I need to add/do anything else; for now here's the part of the log that I think could be interesting, let me know if I should remove/add/do anything else:
Sep 6 18:15:23 kernel: DROP <4>DROPIN=eth0 OUT= MAC=10:bf:48:d3:fa:a0:00:24:c4:27:67:da:08:00 <1>SRC=17.172.232.141 DST=201.185.151.110 <1>LEN=77 TOS=0x00 PREC=0x00 TTL=43 ID=48786 DF PROTO=TCP <1>SPT=5223 DPT=52849 SEQ=4132384475 ACK=1164965254 WINDOW=8008 RES=0x00 ACK PSH URGP=0
Sep 6 18:15:23 miniupnpd[606]: received signal 15, good-bye
Sep 6 18:15:23 syslog: SNet version started
Sep 6 18:15:23 miniupnpd[616]: HTTP listening on port 39975
Sep 6 18:15:23 miniupnpd[616]: Listening for NAT-PMP traffic on port 5351
Sep 6 18:15:26 kernel: DROP <4>DROPIN=eth0 OUT= MAC=10:bf:48:d3:fa:a0:00:24:c4:27:67:da:08:00 <1>SRC=199.47.219.149 DST=201.185.151.110 <1>LEN=219 TOS=0x00 PREC=0x00 TTL=52 ID=7064 DF PROTO=TCP <1>SPT=80 DPT=50778 SEQ=1617341534 ACK=2764185150 WINDOW=63784 RES=0x00 ACK PSH URGP=0
Sep 6 18:15:26 kernel: DROP <4>DROPIN=eth0 OUT= MAC=10:bf:48:d3:fa:a0:00:24:c4:27:67:da:08:00 <1>SRC=176.34.110.202 DST=201.185.151.110 <1>LEN=124 TOS=0x00 PREC=0x00 TTL=40 ID=5849 DF PROTO=TCP <1>SPT=5223 DPT=35601 SEQ=932068050 ACK=1872094027 WINDOW=122 RES=0x00 ACK PSH URGP=0 OPT (0101080A223C67600058ED78)
Sep 6 18:15:36 dnsmasq-dhcp[500]: DHCPREQUEST(br0) 192.168.1.13 00:37:6d:fd:93:9c
Sep 6 18:15:36 dnsmasq-dhcp[500]: DHCPACK(br0) 192.168.1.13 00:37:6d:fd:93:9c android-4cbf963ae2ea93f0
Sep 6 18:15:49 kernel: DROP <4>DROPIN=eth0 OUT= MAC=10:bf:48:d3:fa:a0:00:24:c4:27:67:da:08:00 <1>SRC=190.248.1.154 DST=201.185.151.110 <1>LEN=81 TOS=0x00 PREC=0x00 TTL=58 ID=42464 DF PROTO=TCP <1>SPT=443 DPT=53474 SEQ=451751504 ACK=211240277 WINDOW=62780 RES=0x00 ACK PSH URGP=0
Sep 6 18:15:50 kernel: DROP <4>DROPIN=eth0 OUT= MAC=10:bf:48:d3:fa:a0:00:24:c4:27:67:da:08:00 <1>SRC=190.248.1.154 DST=201.185.151.110 <1>LEN=81 TOS=0x00 PREC=0x00 TTL=58 ID=42465 DF PROTO=TCP <1>SPT=443 DPT=53474 SEQ=451751504 ACK=211240277 WINDOW=62780 RES=0x00 ACK PSH URGP=0
Sep 6 18:16:07 kernel: DROP <4>DROPIN=eth0 OUT= MAC=10:bf:48:d3:fa:a0:00:24:c4:27:67:da:08:00 <1>SRC=50.22.210.136 DST=201.185.151.110 <1>LEN=73 TOS=0x00 PREC=0x00 TTL=50 ID=3786 DF PROTO=TCP <1>SPT=443 DPT=49372 SEQ=2384867304 ACK=159694981 WINDOW=65535 RES=0x00 ACK PSH URGP=0
Sep 6 18:16:07 crond[512]: time disparity of 885555 minutes detected
Sep 6 18:18:07 kernel: DROP <4>DROPIN=eth0 OUT= MAC=10:bf:48:d3:fa:a0:00:24:c4:27:67:da:08:00 <1>SRC=74.125.139.125 DST=201.185.151.110 <1>LEN=66 TOS=0x00 PREC=0x00 TTL=46 ID=47055 PROTO=TCP <1>SPT=5222 DPT=49206 SEQ=3591152779 ACK=1419792720 WINDOW=41266 RES=0x00 ACK PSH URGP=0
Sep 6 18:18:12 kernel: DROP <4>DROPIN=eth0 OUT= MAC=10:bf:48:d3:fa:a0:00:24:c4:27:67:da:08:00 <1>SRC=74.125.139.125 DST=201.185.151.110 <1>LEN=66 TOS=0x00 PREC=0x00 TTL=46 ID=47056 PROTO=TCP <1>SPT=5222 DPT=49206 SEQ=3591152779 ACK=1419792720 WINDOW=41266 RES=0x00 ACK PSH URGP=0
Sep 6 18:18:15 dnsmasq-dhcp[500]: DHCPINFORM(br0) 192.168.1.160 00:1d:7d:01:8a:3a
Sep 6 18:18:15 dnsmasq-dhcp[500]: DHCPACK(br0) 192.168.1.160 00:1d:7d:01:8a:3a Jkmilo-PC
Sep 6 18:18:23 kernel: DROP <4>DROPIN=eth0 OUT= MAC=10:bf:48:d3:fa:a0:00:24:c4:27:67:da:08:00 <1>SRC=190.248.34.15 DST=201.185.151.110 <1>LEN=1500 TOS=0x00 PREC=0x00 TTL=60 ID=29895 DF PROTO=TCP <1>SPT=80 DPT=56591 SEQ=14875844 ACK=3466516992 WINDOW=14600 RES=0x00 ACK URGP=0
Sep 6 18:18:33 kernel: DROP <4>DROPIN=eth0 OUT= MAC=10:bf:48:d3:fa:a0:00:24:c4:27:67:da:08:00 <1>SRC=190.248.34.15 DST=201.185.151.110 <1>LEN=1500 TOS=0x00 PREC=0x00 TTL=60 ID=29896 DF PROTO=TCP <1>SPT=80 DPT=56591 SEQ=14875844 ACK=3466516992 WINDOW=14600 RES=0x00 ACK URGP=0
Sep 6 18:21:31 kernel: DROP <4>DROPIN=eth0 OUT= MAC=10:bf:48:d3:fa:a0:00:24:c4:27:67:da:08:00 <1>SRC=190.248.34.15 DST=201.185.151.110 <1>LEN=1500 TOS=0x00 PREC=0x00 TTL=60 ID=4037 DF PROTO=TCP <1>SPT=80 DPT=56660 SEQ=1699685063 ACK=111056978 WINDOW=14600 RES=0x00 ACK URGP=0
Sep 6 18:21:41 kernel: DROP <4>DROPIN=eth0 OUT= MAC=10:bf:48:d3:fa:a0:00:24:c4:27:67:da:08:00 <1>SRC=190.248.34.15 DST=201.185.151.110 <1>LEN=1500 TOS=0x00 PREC=0x00 TTL=60 ID=4038 DF PROTO=TCP <1>SPT=80 DPT=56660 SEQ=1699685063 ACK=111056978 WINDOW=14600 RES=0x00 ACK URGP=0
Sep 6 18:21:50 dnsmasq-dhcp[500]: DHCPRELEASE(br0) 192.168.1.160 00:1d:7d:01:8a:3a
Sep 6 18:21:51 kernel: DROP <4>DROPIN=eth0 OUT= MAC=10:bf:48:d3:fa:a0:00:24:c4:27:67:da:08:00 <1>SRC=190.248.34.15 DST=201.185.151.110 <1>LEN=1500 TOS=0x00 PREC=0x00 TTL=60 ID=4039 DF PROTO=TCP <1>SPT=80 DPT=56660 SEQ=1699685063 ACK=111056978 WINDOW=14600 RES=0x00 ACK URGP=0
Sep 6 18:21:51 dnsmasq-dhcp[500]: DHCPDISCOVER(br0) 192.168.1.160 00:1d:7d:01:8a:3a
Sep 6 18:21:51 dnsmasq-dhcp[500]: DHCPOFFER(br0) 192.168.1.160 00:1d:7d:01:8a:3a
Sep 6 18:21:51 dnsmasq-dhcp[500]: DHCPREQUEST(br0) 192.168.1.160 00:1d:7d:01:8a:3a
Sep 6 18:21:51 dnsmasq-dhcp[500]: DHCPACK(br0) 192.168.1.160 00:1d:7d:01:8a:3a Jkmilo-PC
Sep 6 18:23:06 kernel: DROP <4>DROPIN=eth0 OUT= MAC=10:bf:48:d3:fa:a0:00:24:c4:27:67:da:08:00 <1>SRC=99.13.117.177 DST=201.185.151.110 <1>LEN=99 TOS=0x00 PREC=0x00 TTL=111 ID=7077 PROTO=UDP <1>SPT=16423 DPT=17546 LEN=79
Sep 6 18:24:48 kernel: DROP <4>DROPIN=eth0 OUT= MAC=10:bf:48:d3:fa:a0:00:24:c4:27:67:da:08:00 <1>SRC=24.41.145.162 DST=201.185.151.110 <1>LEN=95 TOS=0x00 PREC=0x00 TTL=114 ID=8740 PROTO=UDP <1>SPT=45835 DPT=17546 LEN=75
