Padavan cant read HFS?
arul
Padavan cant MOUNT HFS?
It used to work. Anybody knows why is this happening? if i use his fw -018 and older, it works just fine.
system logs
this is the system log shows when i plug my partitioned hdd
HFS and EXT3
anyone can point out something?
Mar 1 14:58:41 kernel: usb 1-2: new high speed USB device number 6 using rt3xxx-ehci
Mar 1 14:58:41 kernel: scsi4 : usb-storage 1-2:1.0
Mar 1 14:58:43 kernel: scsi 4:0:0:0: Direct-Access WD My Book 1140 1016 PQ: 0 ANSI: 6
Mar 1 14:58:43 kernel: sd 4:0:0:0: [sda] 3906963456 512-byte logical blocks: (2.00 TB/1.81 TiB)
Mar 1 14:58:43 kernel: sd 4:0:0:0: Attached scsi generic sg0 type 0
Mar 1 14:58:43 kernel: scsi 4:0:0:1: Enclosure WD SES Device 1016 PQ: 0 ANSI: 6
Mar 1 14:58:43 kernel: sd 4:0:0:0: [sda] Write Protect is off
Mar 1 14:58:43 kernel: sd 4:0:0:0: [sda] Mode Sense: 47 00 10 08
Mar 1 14:58:43 kernel: sd 4:0:0:0: [sda] No Caching mode page present
Mar 1 14:58:43 kernel: sd 4:0:0:0: [sda] Assuming drive cache: write through
Mar 1 14:58:43 usb_modeswitch: no rule for device 1058:1140
Mar 1 14:58:43 kernel: scsi 4:0:0:1: Attached scsi generic sg1 type 13
Mar 1 14:58:56 kernel: sda: sda1 sda2
Mar 1 14:58:56 kernel: sd 4:0:0:0: [sda] No Caching mode page present
Mar 1 14:58:56 kernel: sd 4:0:0:0: [sda] Assuming drive cache: write through
Mar 1 14:58:56 kernel: sd 4:0:0:0: [sda] Attached SCSI disk
Mar 1 14:58:58 automount: Unable to mount device /dev/sda1 (hfsplus) to /media/ARUL!
Mar 1 14:58:58 kernel: EXT3-fs: barriers not enabled
Mar 1 14:58:58 kernel: kjournald starting. Commit interval 5 seconds
Mar 1 14:58:58 kernel: EXT3-fs (sda2): warning: maximal mount count reached, running e2fsck is recommended
Mar 1 14:58:58 kernel: EXT3-fs (sda2): using internal journal
Mar 1 14:58:58 kernel: EXT3-fs (sda2): mounted filesystem with ordered data mode
the ext3 is mounted and is read/write(able), but not on the hfs. what should i check?
Oops, I didn't notice that you had a second drive attached. Not sure what to say. I think there are some check disk commands for HFS included in Pavadan's firmware. I can't remember the actual commands though, I'm not on a network right now that is running the firmware.
