I just installed the latest Padavan firmware on my RT-N56U and it has a GreenAp feature. My question is, does this only work for non N cleints or will it also work for single stream N cleints? For example all my wireless connected devices are single stream N(iPhone, iPad..etc), if I turn on GreenAP will the router sense this and revert down to the power saving single stream mode? If not should I just manually set the router to 1T1R mode? Is there any benefit to turning on 2T2R and 2T3R if the cleints are only single stream?
thanks
thanks
