Hello.
I'm sure others having similar issue with parental control vs. iPhone that use "private MAC",... although I'm not finding any good solutions? The problem is that the default private MAC setting makes it really hard to consistently identify the child devices = inconsistent application of parental controls. Thanks in advance for any ideas you might have.
Situation:
Any other ideas?
Situation:
- ASUS router with Merlin and YazFi installed. YazFi allows assigning special DNS servers for each Guest Network. Also creates separate subnets for each Guest Network.
- Guest Network 1 = IOT devices. Super secret password.
- Guest Network 2 = my son's school iPad. YazFi redirects DNS to AdGuard Home local DNS server that blocks all "time-wasters".
- Main Wifi SSID = everything else. Default DNS is AdGuard Family.
- I can put a MAC DENY list on the Main Wifi SSID to prevent the IPAD from connecting there. However, I believe that he can get around this by deleting the WIFI connection in iOS and reconnecting,... the IPAD generates a new MAC address and gets around the DENY list.
- I could turn off "Private MAC" but he could just switch it off.
- His iphone is connected to the Main Wifi SSID,... Apple functionality let's you share network credentials between devices,... so able to connect the iPad to the unrestricted Main Wifi SSID.
- I've previously tried to point the iPad to the special DNS using DNS DIRECTOR, but has a similar problem caused by "private MAC" changing the iPad MAC.
- Apple ScreenTime parental controls work pretty good for his iPhone but not possible for the school iPad because school controls it.
Any other ideas?
