Parental control
sjsharks
is there a way to change the parental control time management time slot to 15mins instead of one hour so the allowed internet access could be, say from 10:00am to 12:30pm?
If not, is there a plan to update the firmware to enable this?
I would be happy if the parental controls would work at all. They don't cut existing connections for games and voicecom like Skype. Pretty much useless in the current state.
Asus Parental control is more useless than you think; I am hoping to make enough noise to wake up Asus into fixing the Parental Control issues - we are fed up Asus !!
Since Parental controls are so out of whacked, I ended up putting dd-wrt Kong build on.
at least parental controls, and what I need works
www.desipro.de/ddwrt/K3-AC/
