Persistent Port Forwarding?
rljames
I needed to "Open" a port (5432) via RT-AC66U v378.54_2 Merlin firmware to support a networked SQL dB.
Worked as expected after adding correct info to "WAN -> Port Forwarding List", setting "Enable Port Forwarding = Yes" and "Applying" the config to router.
But after resetting the "WAN -> Enable Port Forwarding = No", the port appears to remain Open?
Is this normal?
Thanks,
Bob
Is this normal?
Thanks,
Bob
Keep in mind that if a client is already connected, it will remain connected. The firewall automatically allows established TCP session in, as part of conntrack.
